by Mobilemick Investigator
Huawei MediaPad T3 10.0 and adobe
I have just got a Huawei MediaPad T3 10.0 and adobe wont work on it, is there anything optional i can use to view PDF
14 REPLIES 14
Re: Huawei MediaPad T3 10.0 and adobe
Hi @Mobilemick
Welcome to the community.
What happens when you try to use it?
When i goto a certain website, i have to view wiring diagrams as PDF`s,  It then tells me to download adobe, They provide the link,
But when i go back to it, it still tells me to install Adobe 🙂
Just checking it will support Adobe,
by Legend
Legend
You tried downloading the app from the play store?
Yes, tried a couple of other ones as well
EE Employee
Hi @Mobilemick
Are you now able to view PDFs?
Many thanks,
Lee
I can read PDF`s on my tablet, its just when i need to view them on that website, it wont let me
EE Employee
Hi @Mobilemick
Which website is it?
I will try and help.
Many thanks,
Lee
I`ll post the link, but it is a paid site, so you`ll not be able to get to the information i need to view
I think this guy has found the problem,
When a browser like Chrome on Android gets a PDF link and offers you the ability to open the file in Acrobat it's only the URL that gets sent across to Acrobat, if the site you are loading the PDF from required a login to access the material when Acrobat requests the file, it may well be getting back a HTML login page instead of the PDF, which it can't render.
This is why if you download the file first and then open it in Acrobat it all works fine""
EE Employee
Hi @Mobilemick
That is similar to what I have to do for a football website 🙂
Cheers
Lee
And did you manage to fix it ?
EE Employee
Hi @Mobilemick
I had to download the PDF file first and then open view a PDF viewer.
Many thanks,
Lee
I dont want that, i want to view in browser, or id use all my data 🙂
EE Employee
Hi @Mobilemick
Viewing in your browser and downloading the PDF would use the same amount of data.
Many thanks,
Lee
