by Bmiles Investigator
How can I turn off predictive text on my Doro 7060.
I have tried to turn off the predictive text as suggested on your forum page, but when I go to 'set' it takes me to 'settings' and shows the option of 'personalisation', but I cannot find anywhere here to turn off the predictive text. Am I looking in the right place?
Solution
Re: How can I turn off predictive text on my Doro 7060.
Hi @Bmiles
Welcome to the community.
I've checked the Doro 7060 user manual. It seems you should be looking for Input Method.
Tap Settings > Personalisation > Language > Input methods > Change from predictive text.
This will change the default input method for writing.
Chris 🙂
Solution
Hi @Bmiles
Chris 🙂
Thankyou very much this has worked.Sent from Samsung tablet.
