by schrodinger56 Valued Contributor
Valued Contributor
Heart Rate?
Is it possible to set the Watch 4G to automatically measure your heart rate say every one hour and record it on your Samsung phone's Health app?
by Ace Contributor
Solution
Re: Heart Rate?
Yes it does this automatically if you set it up.
BrendonH (Android Expert) - Samsung Galaxy S8+ (Pie 9.0 Beta)
If I have helped you please click on the STAR/SOLUTION buttons below
1 REPLY
by Ace Contributor
Solution
Re: Heart Rate?
