by Healy903
Galaxy watch not connecting to mobile network after phone upgrade
Upgraded to the s10 and attempted to connect my watch works perfectly via bluetooth but when trying to activate mobile connection I'm faced with this error? "Couldnt set up service, your watch has already been signed up for a mobile data plan" I've tired resetting multiple times and also using my old s8 with no luck
Any help appreciated
by Ace Contributor
Solution
Re: Galaxy watch not connecting to mobile network after phone upgrade
Hi @Healy903
Welcome to the EE Community,
if you give the tech team a call on 0800 956 3146 they will be able to reset the watches esim which will then allow you to connect.
Thanks,
David.
by Ace Contributor
Solution
Hi @Healy903
Thanks,
David.
by Healy903
Thanks David,
Will give them a ring tomorrow hopefully will be a simple fix 🙂
Recent solutions
