by VladimirB Investigator
EE Nokosi phone with Whatsapp builtin
Nokosi phone was purchased in April this year. Whatsapp application was used during summer. Now app says :"Update Whatsapp. Tap "download" to get latest version"
I can download file using link provided. File named Whatsapp.apk (33.25 Mb) downloaded.
Phone asked then: "Do you want to install this app? It will get access to:". I have two options: "Cancel" or "Install". I choose "Install". App installing....  Installed. Two options again: "Done" or "Open". I choose "Open" and got message about Whatsapp update again. So it's indefinite loop. Have done it several times, no progress.
I can't use Whatsapp application which was main reason for purchase.
What should I do, EE?
Solution
Re: EE Nokosi phone with Whatsapp builtin
Problem solved.
Old 4Gb micro SD card was installed. Default storage changed to SD card(Phone has very limited storage).
Full reset performed. Now it's updated and working.
Thanks to everyone.
7 REPLIES 7
Hi @VladimirB
Welcome to the community.
Could you try restarting the phone and trying again please?
Have you tried deleting and re-downloading the app?
Yes, I did restarts/reboots. It doesn't help. As I understand, phone is running under Anrdoid OS with Google services removed. For me it looks like app can't get permission/s from OS during install process. There is no firmware update from EE available as well (and it doesn't look like it will be in a future).
OK thanks, @VladimirB
I recommend speaking to our Tech Gurus to see if there's anything they recommend.
Don't run it from the "Done" or "Open" prompt but from its icon on your Home screens or Apps.
if I click on icon (Home screen) the update message appears. Loop again.
Solution
Problem solved.
Thanks to everyone.
Glad you got this sorted @VladimirB
Thanks for coming back and letting us know 🙂
Leanne
