by iowian Investigator
Does anyone know how to display a video full size using th EE hawk phone?
8 REPLIES 8
Re: Does anyone know how to display a video full size using th EE hawk phone?
Hi Chris
Yes I'm launching from Whatssap. Hmm the phone memory how does that work? Thanks
Get Outlook for Android
by Ace Contributor
Hello @iowian tap the video when watching to bring up the player controls at the bottom then full screen mode will be one of the options on the right.
Hi tm90.
I can't get that to happen when the video is sent via whatssap. Is that right?
Hi @iowian
Welcome to the community.
Are you launching the video from Whatsapp?
Has the video saved to your phone memory too?
Hi Chris
Yes I'm launching from whatssap. As for phone memory, not sure how that works at the moment
by Ace Contributor
Are you watching the video in the Whatsapp app or have you saved it and and are watching it in the gallery/photos app?
Sometimes the video does not stretch to fill the screen even in full screen mode. It depends on the resolution of the video.
Thanks tm90. I will check this out.
Hi @iowian
Please let us know how you get on.
Cheers
Richard
