by mikebeas
New Member
Sole trader thinking of going to Osprey 2 problem is my usage is around 200gb
Sole trader thinking of going to Osprey 2 problem is my usage is around 200gb a month.
How much would this end up costing me if biggest plan is 50gb? Scary amount?
Solution
Re: Sole trader thinking of going to Osprey 2 problem is my usage is around 200g
Hi @mikebeas,
Welcome to the Community.
Does the whole 200GB need to be used away from your home/place of work?
It may be better value to use a combination of fixed line broadband and mobile WiFi.
Hope this helps.
Solution
Hi @mikebeas,
Hope this helps.
