by Danpedrosa88
How do I buy a signal booster
Hello,
how do do I buy a signal booster for my house?
Thanks,
Dan
Re: How do I buy a signal booster
@Danpedrosa88   if you need a signal booster you can go to an EE store and purchased one.  If you’re on contract does your device support Wi-Fi calling ?
by Danpedrosa88
Thanks Chris.  WiFi calling is not that reliable so I’ll try go into a store and get the signal booster.
@Danpedrosa88  not that reliable? I use it every day at work between six different buildings not once losing signal and without it I might as well just turn my phone off.
by Danpedrosa88
Sounds like you’ve got it good. It has periods where it is flawless then periods where it is utter crud.
Sent from my iPhone
@Danpedrosa88   WiFi calling is as only as good as the strength of the WiFi signal. Sometimes just relocating the router can make a big difference.
