by Naak
Hi
Amazon prime
Re: Hi
by Brilliant Contributor
Re: Hi
Good content on there. I suggest you get it.
Your first watch should be The Bad Boys
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Re: Hi
Hello @Naak
Welcome to the community 🙂
Would you like Amazon Prime Video?
If so, text PRIME VIDEO to 150 and follow the set up instructions 🙂
