by mrseric7
New Member
Discounts after upgrade
I've just upgraded my daughter's iPhone that had a 20% Defence Discount applied to it. Will this continue or will it need to be reapplied?
by Ace Contributor
Solution
Re: Discounts after upgrade
Hi @mrseric7
Welcome to the EE Community,
for the discount to carry forward you would of needed to register for EE perk where you will be given a code.
https://perk.ee.co.uk/
unfortunately you would need to return the upgrade if you upgrade online or over the phone and then upgrade again.
Thanks,
David.
by Ace Contributor
Solution
Hi @mrseric7
Thanks,
David.
