by CleanForest Contributor
Can i trade in my old phone in store or does it have to be done by post.
Can I trade in my old phone in store or has it got to be done by post.  It says pop into any store but I want to make sure.
Solution
Re: Can i trade in my old phone in store or does it have to be done by post.
Hi @David_C
You can use the value earned from your trade in to discount for any of the below;
  • Your early upgrade fee
  • The up front cost of your new device
  • Accessories
Or you just have the money transferred back into your bank account directly
Leanne 🙂
8 REPLIES 8
Hi @CleanForest.
In addition to @Chris_B's reply, you can find your nearest store on our online store finder.
Find out more about trading your phone in >
Chris 🙂
by Ace Contributor
@CleanForest if you do it instore they wont give you cash you will get a gift card that you can use in store.
Solution
Hi @David_C
  • Accessories
Leanne 🙂
by Ace Contributor
@Leanne_T  when I went to a store to trade in before your colleague said I could only use it instore.
Have the process changed over the last 12 months ?
Hi @David_C
Yes, this was formerly known as Recycle and Reward.
Full information can be also found within How do I trade in my old device with EE?
Leanne 🙂
by Ace Contributor
Ok thanks for clearing that up @Leanne_T
No problem at all @David_C 🙂
