by dorr426
Amazon Prime
I took advantage of the free 6 months of amazon Prime. It's not due too expire until January 13th however I recieved an email from amazon on October 18th saying my membership has ended. I changed my sim only deal but kept the same number but I wonder if this had something to do with it?
by Ace Contributor
Solution
Re: Amazon Prime
Hi @dorr426
Welcome to the EE Community,
Is it still showing on your account if you log into MyEE under add ons ?
If it is use this link again and it will reactivate your subscription for you.
http://www.ee.co.uk/primevideo
Thanks,
David
by Ace Contributor
Solution
Re: Amazon Prime
Hi @dorr426
Thanks,
David
by dorr426
Re: Amazon Prime
Thank you very much !! This has fixed it, much appreciated 🙂
by Ace Contributor
Re: Amazon Prime
@dorr426 your welcome 😊
Recent solutions
