by david441
signal
there seems to be a problem with the mobile signal in reedness and surrounding villages
its been like this since before Christmas any idea when the problem will be fixed
   thanks
by Prodigious Contributor
Solution
Re: signal
Hi @david441,
Welcome to the community!
I can confirm that there is a network outage in Reedness currently, and engineers are working to fix the issue.
You can subscribe to updates and be notified when the issue is resolved by visiting https://myaccount.ee.co.uk/networkchecker/checkservice, entering your post code, click Keep me posted and complete the on-screen form.
Thanks,
Alex
If I solved your issue, please click the 'solved' button below to help others!
Solution
Re: signal
Hi @david441,
Thanks,
Alex
