by Sezzamunchkin Investigator
Why won’t my phone connect to the network?
My daughters phone won’t connect to EE, she can only make calls when she has WiFi. Please help!
Re: Why won’t my phone connect to the network?
I took the phone into Apple today and they said it was an antennae or hardware problem so not fixable unless they send it away.
Thank you for the reply 😊👍🏻
Sent from my iPhone
by Ace Contributor
Has you daughter been able to previously connect to EE ?
If you haven't already tried this, switch the phone off and then back on, as sometimes this can make the phone connect.
Also, enter the postcode for the area where you have this issue, into the EE Service Checker and see if there are any issues in that area.
https://myaccount.ee.co.uk/networkchecker/checkservice
Good Morning @Sezzamunchkin
What phone is she using?
Are you with us on pay as you go or pay monthly with your daughters account?
Speak soon.
@Sezzamunchkin  Is airplane mode enabled by any chance.
I took the phone into Apple today who said it was an antenna or hardware problem. So it’s the phone not the software.
Thanks for your reply 😊👍🏻
Sent from my iPhone
Recent solutions
