by Leew1968 Investigator
Signal Booster
Hi everyone,
I am actually with PlusNet, but they use the EE network. My question is this: Where I live the signal is quite poor(no provider is great here), a friend of mine has a Cisco signal booster in her house(connected to her router,obviously!) & when I am there I have a much improved signal. If I was to purchase one & connect it to my router(also on PlusNet) would it give me the same benefit or do I need a contract with EE(or use them as my provider), I have been on to PlusNet & unfortunately they don't do one. Thanks in advance for any help/replies! 🙂
Lee.
Solution
Re: Signal Booster
Hi @Leew1968
 Plusnet isn't EE, they just pay EE to use their network. They are not the same.
EE signal boxes are EE account specific, so no unless you are an EE customer and you cannot use EE VOWIFI then it's unlikely you would get one.
You need to speak to Plusnet about options they provide.
Solution
Re: Signal Booster
Hi @Leew1968
Re: Signal Booster
Good Morning @Leew1968
Thanks for coming the community 🙂
I can see @Northerner has provided you an answer. I would also recommend contacting PlusNet and see all options available.
It would be great if you could keep us posted with your progress,
Katie
Re: Signal Booster
Hi Northerner,
That's what I thought, Thanks for the reply, I had to ask but was already quite sure that the answer you gave me would be the answer I'd get! 😉
Thanks again,
Lee.
Re: Signal Booster
Hi Katie,
I had already asked PlusNet if they did one(don't see why they can't do a deal with EE to supply them?) But unfortunately they don't, hence the question.
Northerner gave me the answer I expected!
Thanks for your help(everyone who replied).
lee.
Recent solutions
