by Jumi1
Network connection problems on my phone
Need help with network connection on my phone
Solution
Re: Network connection problems on my phone
Hi @Jumi1
Welcome to the community.
As @Peter_C said, we'll need to know a little more about what's happening so that we can help you.
Our network status checker should be a good place to start, to check if there are any maintenance works in your area.
by Star Contributor
Star Contributor
Could you tell us a little bit more about the problems you have been having so that we can help?
Solution
Hi @Jumi1
by Jumi1
Thanks @Peter_C and @Christopher_G, the issue has been resolved now. My son swapped our SIM cards arround, we are upgrading phones So the phone couldn't pick up the network.
Great news @Jumi1.
Glad you're back up and running. 🙂
