by stu0379
EE Signal
Hi, I'm in the RG26 5 area and wondered when or if there are plans for a signal upgrade?
Re: EE Signal
Hi @stu0379
Have you checked EE network checker, and if no problems reported one?
EE won't say when or if any masts will be upgraded generally.
by stu0379
Re: EE Signal
Thanks for that, will that a try. 👍
EE Community Team
Re: EE Signal
Hi @stu0379,
Welcome to the community 🙂
Did you manage to find what you needed on our Network Status Checker?
As @Northerner suggested, you can also report any issues if there are none showing for your postcode.
Our Tech Gurus will also be able to look into your account. Do you know if other people are experiencing a problem in that postcode on EE?
Alex 🙂
Recent solutions
