by Gfys Established Contributor
EE APN Settings
Hi does anyone have any idea about the APN settings for EE because mine isn't correct ( I don't think ), they don't match the ones on a EE site , I am unsure if the APN settings I have found is for broadband or mobile , i can't edit the ones either i have on my mobile.
Thank you in advance for any advice and help.
by Brilliant Contributor
Re: EE APN Settings
Hi @Gfys
Please CLICK HERE to review the current APN Settings process.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Re: EE APN Settings
This is what I have , thank you for your reply.
by Ace Contributor
Re: EE APN Settings
Hi @Gfys
Try this EE settings configurator
http://setup-ee.wdsglobal.com/
