by DomH Investigator
Can't make calls. No mobile network
Hello. I cannot make calls and have no mobile network. Help please.
Solution
Re: Can't make calls. No mobile network
It's now fine. Didn't do anything and it eventually found the network. Thanks.
@DomH : Have you checked the Network Status Checker there & logged the problem?
Checked. And it is showing no problems where I live and where I work - so it's not that.
Colleague has an we phone and no problem. Its my phone for sure. Huawei mate 20 lite.
Any advice please?
Thanks for confirming this @DomH
Are you able to try your SIM in another device to see if the issue continues?
If it does, I would recommend a replacement SIM which you can get by taking valid photo ID into your local EE Store or by giving us a call
If the issue stops, I would recommend speaking with our technical care team.
Please keep us updated on your progress,
Katie 🙂
Solution
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Recent solutions
