Highlighted
WHeres my phone?
Hi I ordered a phone to be delivered to store yesterday got a confirmation email last night but have heard nothing today. How long does it take?
Highlighted
by Ace Contributor
Solution
Re: WHeres my phone?
Hi @Millieb123x
once your item is dispatched you will get a notification either via text or email. You can also track your order online using your order number in your confirmation email . If the item is in stock, it’s usually dispatched within 1-2 days . You can always call your local store to see if it’s arrived.
hope this helps.
Highlighted
by Ace Contributor
Solution
Hi @Millieb123x
hope this helps.
