06-04-2020 09:14 PM
When I joined EE I added some products to my plan, unfortunately I've heard nothing about these? & also have no way of tracking the order.... may someone help or give me some advice so I know what to do & what to expect?
Kind regards.
08-04-2020 08:18 AM
Good Morning and welcome to the EE Community @Amy86.
What products did you add to your plan?
Did you do this online?
Did you receive a confirmation email?
Speak soon,
Katie 🙂
27-06-2022 12:44 PM
Hi i have also added products to my plan and have not received any further communication, how long does this usually take thanks.
27-06-2022 01:10 PM
Hi there @Socko1701
Thanks for coming here 🙂
When did you place the order and which add to plan product did you order?
Thanks.
27-06-2022 01:14 PM
I ordered on the 20/06, and it was a pair of Beats Studio Headphones.
27-06-2022 01:25 PM
Thanks @Socko1701
If you give us a call on 150, the team will check the order for you and give you an update 🙂
27-06-2022 01:26 PM
Which menu option should i go to as there is none for Add on Products. Thanks
27-06-2022 01:29 PM
Hi @Socko1701
If you select option 1 for mobile, then any account option to speak to an advisor they can check the order for you 🙂
