by SophS1901
New Member
How long until my order arrives?
Hi.
I ordered a Good As New iPhone XR on Friday 1st October. I have received a confirmation email of my order, but there is no information on exactly when, or how long until, it will be delivered. I can't find any information to help - does anyone who where I can find any, or have an answer?
Thanks in advance!
by Ace Contributor
Solution
Re: How long until my order arrives?
Hi @SophS1901
Welcome to the EE Community,
I would recommend speaking to the sales team on 0800 956 6000 opt 2 opt 1 they will be able to look at your order for you and give you any updates.
Thanks,
David.
by Ace Contributor
Solution
Hi @SophS1901
Thanks,
David.
by Dazz3012
Hi did you get your order
