by joelazevedont
Can’t track my order
Re: Can’t track my order
Hi @joelazevedont
You will need to speak to EE CS on 150 if tracking isn't working.
Hi @joelazevedont,
Which model did you order?
by joelazevedont
It’s an iPhone 11 Pro Max 256gb
Hi there @joelazevedont
Thanks for confirming.
If you get in touch with our Mobile Care team on 150, they will be able to check the order for you and make sure the reference is correct for the online order tracker.
Thanks.
Recent solutions
