by Enzom Investigator
30 GB instead of 60 GB
On Black Friday i i graded my sim from 20 GB to 60 GB for the same price. I thought i would get a new sim but as yet I've heard nothing and I've just checked on my app and for some reason EE have gave me 30 GB. Not sure what's going on. Any info would be appreciated. Thanks
by Ace Contributor
Solution
Re: 30 GB instead of 60 GB
Hi @Enzom if you give 150 a call the black Friday 60GB deal for £20 comes with a 30GB plan & two free data add ons making it 60GB.
6 REPLIES 6
@Enzom  You’ll need to speak with customer services about this. You don’t get a new sim if you don’t need one and you don’t as it’s just an account change.
Hi @Enzom
You won't get another SIM unless you asked for one.
As for the data issue, then search the forum and read the other posts.  You will see what EE policy is on your upgrade of data.
I suggest you call CS on 150.
by Ace Contributor
Solution
Thanks for the help and support.
by Ace Contributor
@Enzom  your welcome if you need any further help in the future feel free to ask here on the community 😊
Thank You i will call CS. Thanks for your reply.
