by Matrix44
New Member
Discount loss
I have some discounts running on my sim.
I would like to know if I will lose this discount if I update my sim card to one of the latest SIM's on offer ?
Solution
Re: Discount loss
Hi @Matrix44
Discounts are normally promotional at the time of your SIM unless it's one such as EE friends and family. Because of this then when you change your plan/tariff you will forfeit any discounts which were in place on your previous plan, for those on your new plan..
There is no account access on these forums, so for specific advice then I suggest you call EE CS on 150.
Solution
Re: Discount loss
Hi @Matrix44
Recent solutions
