by sharon1670 Valued Contributor
Valued Contributor
how to remove the chat help pop up from my screen while using the 'my ee app'
hi is there a way to remove the chat help pop up from my screen while using the 'my ee app' its so annoying.. it's asking if i need help...yes i need help i need ur pop up to disappear off my screen so i can pay my damn bill properly 🤦
Re: how to remove the chat help pop up from my screen while using the 'my ee app
Hi @sharon1670
When it asks if you need help, can you not just select 'no'?
Or is there a 'x' symbol in the top right corner?
What is the make and model of the device that you're using the app on?
Look forward to hearing from you.
Chris 🙂
Valued Contributor
hiya thanks for replying.. i'm using the LG G5+no there isn't an 'x' +if i
press it i'm redirected to the help page with a message saying a EE
representative will be with u shortly so if i sack them off+return it
appears again..one time it caused me to double click+two payments went
through.. 🤔
Hi @sharon1670,
I'm not sure if it's possible to disable this feature.
I'll pass your feedback to the My EE team and let you know if I can find a solution.
