by Stacey15
Why does it keep say my phone number is associated
by Ace Contributor
Re: Why does it keep say my phone number is associated
Hi, @Stacey15  are you trying to register your number?
by Stacey15
Yes but every time I try it says my phone number is associated
There is a MyEE a/c already created for it,
by Ace Contributor
Hi, @Stacey15  you need to ring on 150 where this can be sorted out for you.
Hi @Stacey15.
If you get in touch with our Mobile Care team they will be able to help you get your account set up 🙂
Jon
