by ValencianO75 Investigator
Roaming not working
Hi I have problem with roaming, not working in Poland .I’m pay as you go costumer
6 REPLIES 6
Re: Roaming not working
Hi @ValencianO75
What problem are you having? As a PAYG customer if you have sufficient credit your account should work.
Hello @ValencianO75
Thanks for coming here.
Have you used the SIM card in the UK before travelling to Poland?
Can you try and connect to a different network in the phone settings;
  • iPhone – Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Speak soon.
Hi never used this SIM card in Uk before travelling to Poland
ValencianO75
Wysłane z iPhone'a
Hi @ValencianO75
Thanks for coming back to me.
The SIM can't be used in Poland until it has been connected to the EE network and used in the UK.
Ok thank you
Wysłane z iPhone'a
Hi @ValencianO75
Hope you have a lovely time in Poland 🙂
