by Asherloi
Roaming and gifting
We’re on holiday in Europe. I know acceptable usage of data roaming is 15gb. I gifted my daughter 12gb which she had almost used up. Since that 12gb was mine to begin with does that mean I only have 3gb of acceptable roaming usage left? Or are we still allowed 15gb usage each?
by Brilliant Contributor
Solution
Re: Roaming and gifting
You gifted her the data so it was hers to use
That wont effect your 15gb fair usage
Solution
