by sarah2409
Problem login
I can login my app but not the website why?
9 REPLIES 9
Re: Problem login
What happens when you try? What error msg?
by sarah2409
Re: Problem login
No error message just blank username and password field
Re: Problem login
Me too! Been happening for weeks.
Re: Problem login
Good Morning @sarah2409.
Have you cleared your cache and cookies recently?
Are you able to try a different browser?
Jon
Re: Problem login
@Jon_K : Don't help! Summit wrong your end.
Re: Problem login
Thanks @XRaySpeX.
I'll see if I can find anything out.
In the mean time, have you contacted Mobile Care?
Jon
Re: Problem login
I spoke to CS today about this. They told me to use Chrome as a PC browser as IE & FF may not be compatible. I did so & it worked. But IE & FF worked OK a week or 2 back.
I abhore being forced into using a browser & a company I don't want but I suppose I will have to just to see my bills.
by Eecom
New Member
Re: Problem login
Trying  to  log  in  with " Internet Explorer " for me  , did not, or  does   not  work. if possible try   using  " Google Chrome " . With " Google  Chrome "  , I  successfully  logged  in  with  no  problems. Hope  This   helps.
Re: Problem login
@Eecom : I already said that last week!
