by Skilled Contributor
Skilled Contributor
My EE network monitor
A couple of updates ago, the myEE app introduced a facility to log your location "when your connection fails", and report it back. It seems an excellent idea (think Voda may have had this for a while), so enabled it, disabled all the notifications so it just runs away in the background.. and thought nothing more of it.
Over the weekend I found myself travelling a stretch of road where EE has historically been "ok" but has suffered from handover failures, and 4G800 is now used in the area albeit not solving the problem completely. It just got me thinking, what is the app actually monitoring? Is it lack of coverage outright? Or locations where 4G drops out and devices fallback to legacy 2G/3G layers?
Solution
Re: My EE network monitor
Good Morning @bristolian and @Profile closed.
I've spoken with the relevant team to get an answer on this for you 🙂
The feature records the time and location when signal is lost completely on the phone.
Jon
10 REPLIES 10
Hi @bristolian.
That's a great question!
With it being quite in depth, I'll need to see if I can get some more information for you so that I don't give you anything incorrect.
I'll see what I can find out and report back if I manage to get an answer 🙂
Jon
by Profile closed
Not applicable
Hi, @Jon_K,
Do you have any further information you wish to add? For, @bristolian and Me?
Regards
mAh8v
Not just yet @Profile closed.
I'm doing my best to get an answer for you as quickly as possible 🙂
Jon
by Profile closed
Not applicable
Hi, @Jon_K,
Ok! 😊👍
I guess we can hang on for a while longer!
Regards
mAh8v
Solution
Jon
by Profile closed
Not applicable
Hi, @Jon_K,
The feature does not display the correct date nor time on my device, Sorry 😞
Regards
mAh8v
Have you reported this to our tech care team @Profile closed?
Jon
by Profile closed
Not applicable
Hi, @Jon_K,
Nope! I thought perhap's you could do this for me! 😊
Regards
mAh8v
Hi @Profile closed.
I've sent you a private message to get some more information from you.
Please have a look and get back to me.
Jon
by Profile closed
Not applicable
Hi, @Jon_K,
Ok!
I've just looked in my inbox and it doesn't seem to have arrived yet!
I'll check again in a minute or two!
Regards
mAh8v
