by chrisellison
Is there a way to add multi-factor authentication to MY-EE web login ?
A lot of other mobile providers offer multi factor authentication for login to their web portals ( ie it texts you a code before it will allow you to login) .  is this possible with the My EE website ?
Are there any other ways to secure login to the My EE website ?
Re: Is there a way to add multi-factor authentication to MY-EE web login ?
Hi @chrisellison
Unfortunately it’s not available. I have asked for this for years but it still hasn’t come. Unbelievable that EE still haven’t implemented any two stage authentication process.
My only suggestion is that us use a unique password  and a mixture of icons/letters/Caps. I also use a separate email account so its remote from any of my other accounts services.
Thanks,
