Highlighted
New Member
Help - contract
I have a contract with EE my phone broken I took it to get fixed but with all shops shutting its shut and they don't no when they will be open. I'm a carer and need a phone. I have another phone to use just wanted to check if there's anyway I can transfer my data over to this phone just for a month or two. Obviously still pay for my other phone that's broken as well
Thank you
Highlighted
by Brilliant Contributor
Solution
Re: Help - contract
Hello @Jadelsmith ,
Welcome to the community,
You can just put your SIM card in the other phone, so long as it is either unlocked or EE phone, if locked, it will not matter which phone you use, as the SIM card has your number and so all data etc is with the SIM card. Hope this answer helps put your mind at rest.
Highlighted
Solution
Re: Help - contract
Hello @Jadelsmith ,
Recent solutions
