by Stuart1984
Help accessing My EE
I've verified my email address several times now and it still takes me to the page where it says I need to verify it before I can access My EE.
I cannot get in to manage my products at all.
Is there a bug on the site?
Thanks.
by Ace Contributor
Solution
Re: Help accessing My EE
Hi @Stuart1984
Welcome to the EE Community,
If you give customer services a call on 150 they will be able to delete your MyEE registration and then set up My EE for you again.
Thanks,
David.
by Ace Contributor
Solution
Hi @Stuart1984
Thanks,
David.
by Stuart1984
Hi David, thank you. Is this a bug?
by Ace Contributor
@Stuart1984  it does play up sometimes and by deleting it and setting it up again normally fixes the problem.
by Stuart1984
Brilliant, thanks 🙂
