by Wendystraw Investigator
Help !! Why do I have to use password when acc is flagged use pin ??
by Profile closed
Not applicable
Solution
Re: Help !! Why do I have to use password when acc is flagged use pin ??
Hello @Wendystraw sorry to hear the app log in is not working properly for you. Try turning PIN code sign in off then back on, restarting the app and trying again. You may need to delete the app, restart your phone first and then re-install the app to make sure you have a clean bug free copy on your phone. 🙂
by Profile closed
Not applicable
Solution
Sent from my iPhone
by Profile closed
Not applicable
Glad to hear it is now working for you @Wendystraw come back to the community anytime if there is anything else you would like to know. 🙂
Hi @Wendystraw
Thank you for posting again in community 🙂
Is this now resolved?
Richard
