by EE Community Manager
Screen protectors - any advice?
My turn to ask for some advice from all you experts here on the Community.
Glass screen protector or one of the film ones? I've just taken a glass one off my iPhone as it got a little too cracked and was a little sharp. On the plus side at least it wasn't the actual screen!
I've had those cases in the past with the front cover, but with a plus phone it all gets a bit big.
Recommendations please (and not just "be careful and don't chuck your phone in your handbag ones 😉 )
TIA!
Tiff
Community guidelines Community stars programme
Meet the EE Community teamHow to use the community
7 REPLIES 7
Re: Screen protectors - any advice?
@TiffJ   I only use glass protectors as they don’t peel off after a short period of time.   I get mine from eBay and purchase ones that say 2 for 1 as you then get a spare.   I buy the cheapest ones I can find and they do there job well.  I too get chips so I’ll change them once when I’ve had enough of the chips.
by Profile closed
Not applicable
@TiffJ I'm still a huge fan and advocate of some sort of phone case. At home I take my phone out of its case. But away from home I always have it in a book type case. I don't need a separate screen protector this way. I don't want any part of my phone damaged.
If I were to use a gel case then I'd have a film screen protector, too.
P.S: I actually find that the film screen protector that comes with a phone can itself do a great job for ages. If I do put a SP on then I ensure that I fit it perfectly. I've seen people with brand new phones without cases and with very ill fitted SPs. I don't get that at all!
by Ace Contributor
I've given up with screen protectors now. I used to always buy a Zagg one and spend hours putting them on but all my phone recently I've not bothered with.
by Ace Contributor
@TiffJ  I paid £10 on amazon for a great glass one that also comes with a plastic fitting frame so you get it perfect everytime.  I had one on for 2 whole years with not a mark on it. X
Thanks for your advice @Chris_B @Profile closed  @chistery  @Watkins07.  Still none the wiser but it just goes to show that everyone has their own personal favourites!
I have so far succeeded with a glass protector so I may just buy a new one - or three - and just change it when it starts to get sharp 😉
Tiff 🙂
by Ace Contributor
@TiffJ
I was always crap at getting them perfect til I bought the one with the fitting frame.   It’s survived a few drops without a mark or chip.  Certainly not the most expensive at £10 but it’s worked well and isn’t wonky donkey lol
I have never used them. Most modern mobiles are designed to withstand a certain amount of punishment and adding a screen cover just seems to make the device look scruffy. But it depends on what you have in your bag @TiffJ !!
I do use skin cases as larger phones are a bit slippery, especially the larger glass backed ones like the Note 9 or Galaxy S10+
Recent solutions
