by Alice2202
New Member
New Phone
How long will it take for the new phone to connect to the EE network?
Re: New Phone
Hi @Alice2202
It should connect straight away. Have you upgraded? Can you try your old sim?
Re: New Phone
Hi @Alice2202
Welcome to the community.
Is it a brand new SIM and number or did you upgrade?
As @Northerner said, if it's an upgrade, you should be able to pop your old SIM in and it'll work straight away.
What kind of phone is it?
Recent solutions
