Highlighted
by Established Contributor
Intermittent fault
Afternoon guys,
I seem to be having an Intermittent fault on my Samsung S10, on occasions when people try to call it goes directly to the voicemail it does not even ring.As I say this does not happen all the time ,could there be something wrong with my Sim or the phone its self I have only had it a couple of months..
Thanks in advance..
25 REPLIES 25
Highlighted
Re: Intermittent fault
Hi @SteveRob1
Have you checked your local network for issues?
https://myaccount.ee.co.uk/networkchecker/checkservice
Are you using WiFi calling when this happens?
Highlighted
Yes mate says "NO KNOWN PROBLEMS"
Highlighted
Does it make any difference if it says vo)) LTE1 in the bar at top of screen?
Cheers
Highlighted
Still no good, just asked my bro to call and its saying"currently unavailable"
Highlighted
Hi @SteveRob1
Have you WiFi calling activated?
It's likely that your signal is weak so it cannot connect the call. VOLTE is voice over data.
Try setting - connections - mobile network and deactivating VOLTE if possible.
Highlighted
 VOLTE  is deactivated, still getting the same
Highlighted
Hi @SteveRob1
Have you got WiFi calling active?
Highlighted
by Ace Contributor
Hi @SteveRob1
Great advice from @Northerner already - VoLTE is 4G-voice explained here - as you've probably discovered, this shouldn't really be disabled except to help diagnose a fault. It improves your service.
Apart from WiFi calling which you're already trying - when a call goes straight to voicemail, is your phone showing signal (or WiFi calling)?
Is it always calls from the same people that go to voicemail? You may have inadvertently blocked them if so. Or if it's all calls, you may have inadvertently set a "Do Not Disturb"
Highlighted
No mate, I just put the Sim in my other mobile and my brother rang and got through so I think its the mobile had it 29th March so thats poor...
Highlighted
by Ace Contributor
@SteveRob1 Well done, that proves it's something with your phone then.
Check your Do Not Disturb settings, and that you've not inadvertently blocked certain callers. Perhaps even block them and unblock, to prove it.
@Northerner suggestion of WiFi calling is a great one to remember too.
Highlighted
hello mate.
I wouldnt have inadvertently blocked anyone , as some times they get through and others it goes direct to voicemail or says service unavailable..
Cheers
Highlighted
Hi @SteveRob1,
Have you turned on WiFi Calling?
Highlighted
I have tried with it on and off still same result mate
Highlighted
Hi @SteveRob1,
Is the WiFi Calling indicator showing on your phone when the calls fail?
Highlighted
yes mate, I have come to the conclusion that the phone is faulty...
Highlighted
Hi @SteveRob1,
Please get in touch with Customer Care so our Tech Gurus can take a look at this issue for you.
Highlighted
Guys ,
I have just received a new SIM as Customer Services think that may be the issue..as the S10 is a dual sim mobile should it have my EE number in the Sim Card manager section at the mo it has all "Zeros"?
Regards
Highlighted
Good Afternoon @SteveRob1
The number should update automatically.
I would recommend allowing 48 hours.
Katie 🙂
Highlighted
@Katie_B thanks...
Recent solutions
