Highlighted
Data gifting
I'm currently on an unlimited data plan, i've had a text saying my Giftable data is running low? I've not gifted any, does this get used whilst hotspotting? Thanks.
Highlighted
Solution
Re: Data gifting
@Shaun1979  on EEs unlimited data plan you can only gift the first 100 gig of your unlimited allowance so if you’ve used up let’s say 80 gig of that 100 gig EE will inform you that you’ve used 80% of your giftable data,  you still got an unlimited allowance but you’re no longer be able to gift data after you’ve used the remaining 20% or 20 gig of your giftable allowance which is the 100 gig.   Using data to hotspot is still using giftable data from the first 100 gig so if you’ve used your data in this way is doesn’t matter as you can use your data how you please.
Highlighted
Solution
Re: Data gifting
Highlighted
Re: Data gifting
Hi, Thanks for the reply, so after the first 100gig is gone could i still hotspot but not gift it to another device? also does it use the giftable data if i download say a movie etc?
Highlighted
Re: Data gifting
@Shaun1979   Yes you can still hotspot and any data used in the first 100 gig is data used that could of been gifted.
Highlighted
Re: Data gifting
Thank you.
Highlighted
Re: Data gifting
@Shaun1979   no problem and you’re most welcome.
Recent solutions
