by LinseyGray
Contacting EE after leaving
How do I call EE if I have recently left so no longer have a registered number with them?? I have tried many different numbers but all ask the same questions, none of which regard previous customers wanting to enquire about a final bill charge. If I try enter my number, it says it is not accepted?
by Ace Contributor
Solution
Re: Contacting EE after leaving
Hi @LinseyGray
Welcome to the EE Community,
If you ring freephone 0800 956 6000 opt 2 opt 4 you will be put straight through to a advisor.
Thanks,
David.
by Ace Contributor
Solution
Hi @LinseyGray
Thanks,
David.
