close
Cleaning Sim Card?
imMiles
Hi, I am wondering what i can use to clean my sim card, can I use Lens Wipes? The Lens wipes contain Water, alcohol and parfum is it safe to put on a sim card?
If you have already done it, then leave the sim card out of your phone for a while and only put it back in when you can see it is fully dry.
After then put it back in your phone and see if you can get service. If you can get service then all should be ok.
Fatboy71
I would not recommend it.
If the sim card has become dirty, then I would recommend a soft cloth to clean it with that does not shed fluff (a microfibre cloth would be ideal).
well i may of already done it... will my sim card be ok? I did it cause the microfiber cloth i used didnt really do anything
