by Dawn73
New Member
Can I use my phone when I’m New York?
Can I buy a text/call add on for when I am in USA?
Re: Can I use my phone when I’m New York?
Hi @Dawn73
What tariff are you on now as you might be able to use your phone on your current plan.
by Star Contributor
Star Contributor
Hello and welcome to the community.
On some plans, an allowance in the USA is included free of charge, otherwise add-ons exist as per EE's USA roaming page.
Thanks,
Peter
by Barnsley_1988 Investigator
hello, you should be able to use your phone in the United States, make sure you have data roaming turned ON as otherwise you'll make your phone bill rocket. Hope this helps
Recent solutions
