by Brilliant Contributor
Best Laptop
I have decided to go to Uni, (well Open University),
Problem I have at home is when I am on my computer my cat likes to sit on my keyboard 95% of the time.
So I am looking to get a lightweight good battery size laptop so I can go to the local coffee house and do most my work there.
Any good suggestions from you lot? Oh and ideally I would like one with a number pad on the right hand side.
Yes @Chris_B if it turns out to be the best option I may consider a MacBook.
7 REPLIES 7
Re: Best Laptop
@BrendonH  There are many decent laptops available not just MacBooks. Yes I did say that😁.
Re: Best Laptop
Laptops aren't always safe from pets either, @BrendonH.
- Photo from yesterday...
Re: Best Laptop
Cute dog.
My plan is to sit in Starbucks or somewhere really. No pets allowed in there lol.
Re: Best Laptop
That sounds like it's the only way to get some work done @BrendonH!
by Ace Contributor
Re: Best Laptop
@BrendonH
Acer Aspire 3 A315-21 15.6" Looks decent and under £400. Ao have some good deals. This has a number pad also .
Re: Best Laptop
@Watkins07  that is a good little laptop. I do have an Acer notebook now but the battery is shot and it is quite old so need the upgrade.
by Star Contributor
Star Contributor
Re: Best Laptop
Business laptops on auction sites. Generally light, well built with good battery life, and often mega mega cheap for the specification. I recently bought one with a moderately high end i7, 8GB RAM and 240GB SSD for £120 and the battery lasts about 5 hours!
