by ConCon11711 Investigator
problems connecting to PUBG after leaving a match using 4G EE Router
So whenever i leave a match on PUBG, i get stuck on a blank loading screen where the game should initialize and then connect to lobby. I only run in to this problem while using my 4G EE router. I have Sky broadband in my house(belongs to house mate) and i never encounter this issue while using that instead.
I have contacted EE directly but diddnt get very far, am currently waiting on a call back.
Any ideas what could be causing this problem? i have followed the steps to disable the router firewall but the instructions on the EE website are outdated.
Solution
Re: problems connecting to PUBG after leaving a match using 4G EE Router
Okay i found a solution that works for me. There are quite a few steps and i dont think i will be able to type it out coherently. but here we go.
First you need to find the IP address of your PC, so go to your desktop search bar and type in CMD and click "command prompt", type in IPconfig/all and a list should pop up. Find and write down your:
IPV4 address,
subnet mask,
default gateway,
dns servers.
Then i logged in to my router, went to settings > advanced settings > configure wan:
under "connection mode" i selected "static IP" and typed out the information i previously wrote down in these spaces:
ip address:
subnet mask:
default gateway:
MTU: 1500 (this should be there anyway)
Primary dns:
and i left the secondary dns blank. save those settings.
Next i needed to disable DHCP in windows and give myself that same static ip address. (i use windows 10), here is exactly what i did. on my keyboard i hit the windows key and X at the same time and selected network connections > change adapter options > i then double clicked on the active ethernet i am using and it brought up an "ethernet status" window > properties > now there is a list with ticked boxes next to them, on that list should be an option that says "internet protocol version 4 (tcp/ipv4)" and i double clicked it. that should open another window that says  "internet protocol version 4 (tcp/ipv4) properties", you need to select "use the following IP address", you then need to fill out the exact same IP address subnet mask and default gateway as you did on your router settings, where it says "preferred dns server" type in what you set as your "primary dns server" in your router settings. click okay, okay then close. reset your pc to make sure everything is good and you should be able to play the damn game gain haha. GG and GL. took me a long time to figure this stuff out but it works.
- ConCon11711
11 REPLIES 11
Hi @ConCon11711
Welcome to the community.
Which device are you playing PUBG on?
Hi Chris 🙂 i play on PC
Thanks @ConCon11711.
Is it our Tech Gurus who are calling you back?
Are you using the 4GEE Home Router or is it the wireless one?
Jon
I believe it may be. My issue has been raised to a "level two technical query". Still waiting on a call.
Hi @ConCon11711.
Are you using a wired or a wireless connection on the EE device?
Did they give you a timescale on the callback?
Jon
I always use a wired connection for it. They just told me within 48 hours
I'd recommend using a wired connection, but have you tried wireless just to see if it's any better?
Could you update us with the outcome of the call when you receive it?
Jon
sure, i will update.
by RBlake
New Member
Any update on this? We have the exact same issue and used to really enjoy playing this game, in fact it's the main thing we used the Internet for at home, currently looking at alternatives for the Broadband due to how frustrating this is
Hi @RBlake
Thanks for coming here.
Have you reported this to our Tech Gurus?
They will be able to get this looked into for you.
Leanne 🙂
Solution
IPV4 address,
subnet mask,
default gateway,
dns servers.
ip address:
subnet mask:
default gateway:
Primary dns:
- ConCon11711
