by willallen97 Investigator
Hotspotting for PC Games
Is using my hotspot from my pixel 3 for PC games blocked on EE? Ive used it in the past with my iPhone?? I can't connect to any servers for all online games I own.
8 REPLIES 8
by Legend
Legend
Re: Hotspotting for PC Games
Hi @willallen97
Make sure content lock is set to off via your online account. Also make sure you have paired the devices with the correct password.
It may also be that EE are using IPv6.
@Northerner
Content lock is off and I can still use it for everyday web use via hotspot.
I have my settings for automatic IP assigning on the computer.
Will
Hi @willallen97,
Welcome back to the community.
Have you tried contacting the game's developer to see if they are aware of any compatibility issues when using a mobile connection?
@James_B
  • It fails on all of my multiplayer games and both computers I own when I start matchmaking
  • It worked previously on my old contract with my iphone..?
Will
You may be up against a limitation of EE's mobile network. The EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
@XRaySpeX
Anyway to fix this? It used to work before on my iPhone? Changing my IP settings on PC or like a VPN?
Will
Update: I switched my sim from my pixel 3 to my old iPhone. It worked fine through that...thoughts?
Just a guess but try switching between IPv6 & IPv4 in your phone's APN if you can.
