by EeCw Investigator
Hotspot NAT Failed on PS4 (BT fine)
Hiya,
I have this problem using EE hotspot from my OnePlus 6T. It used to work with this phone and SIM but now I get NAT Failed when hotspot from my PS4 Pro.
If I use a BT SIM in this phone, it works fine. Something must have changed on the EE network.
I read elsewhere they recently changed to IP6?
I can connect to internet. I can play games. I just cannot NAT so this prevents game chat and online play.
Will update if I find a solution.
6 REPLIES 6
Re: Hotspot NAT Failed on PS4 (BT fine)
@EeCw : Can the OnePlus be forced to use IPv4 only in its APN?
Thanks for the suggestion. I already tried that but no change
by Doctor_T Established Contributor
I'm having the same issue but with the pixel 3. The same EE SIM works fine in a nexus phone.
Can't get it to work.
Good luck if you do.
Thanks, I'll be in touch if I get it working. I've also raised the point with OnePlus as it's ok on my old 5 but not my 6T so it seems to be fussy about phone+carrier mix.
I got mine sorted. See my thread which I initiated. Hopw it helps.
Hi @EeCw.
Have a look at @Doctor_T's other thread as they managed to find a solution using an APN 🙂
Jon
