by Star Contributor
Star Contributor
Blocked ports and cloud gaming
All
Any ideas on what ports are blocked on EE.
I'm trying to use LiquidSky and just get a blackscreen however if i VPN it works.
9 REPLIES 9
Re: Blocked ports and cloud gaming
@Bellyman   Silly question but why would EE block a gaming website.    Perhaps they need to update their servers to IPv6 so it except the connection.
by Star Contributor
Star Contributor
You may have misunderstood cloud gaming with btowsing to a gaming website
@Bellyman: On which EE network? Home Broadband or the mobile network? Are you going thro' a router?
by Star Contributor
Star Contributor
Hi
This is on an Android device over 4G.
So i have no issues via an ISP connection but a blackscreen with EE.  I'm 99% sure its a port issue and would like more info on that.
EE block no ports on their mobile network.
However, EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net. This is unlike fixed BB. This will cause problems if you are hosting a gaming server & other gamers are making unsolicited attempts to access your server from outside on the Net.
by Star Contributor
Star Contributor
Thanks. Whilst not the same circumstance CGNAT could be the cause.
Looks like i'll be using a VPN.
Thanks! You're welcome Smiley Happy! Glad I could be of assistance.
What are the circumstances exactly?
by Star Contributor
Star Contributor
Liquidsky is a cloud gaming services and it looks like a many more are coming even Google and Xbox.
You rent time on a high spec cloud gaming PC so you can play PC games on almost any device.  So i've been playing Fortnite on my S8 but the wifi in work is trash so thought 4G would be better... turns out i couldn't even start to try.
by Star Contributor
Star Contributor
I post i added to the liquidsky forum was updated with
"Some mobile carriers have issues with this service- to my recollection those who had issues switched carriers and were able to use this service afterwards. I don’t recall that there were specific ports or anything for this service."
So it can work but depends on something...
