by amovaosobul
flex plan
I moved to EE from Tesco Mobile, because the offer was much better, but I can't set up Flex Plan for £10. How to do it? I tried on my EE, but it doesn't show this option.
by Ace Contributor
Re: flex plan
Hi @amovaosobul
Welcome to the EE Community,
I would contact customer services on 150 they will be able to change it for you.
by amovaosobul
Re: flex plan
Hi Dear. Thank you for your response. Is any chance to do it online?
by Ace Contributor
Re: flex plan
@amovaosobul unfortunately you cant
If you got access to a landline ring 0800 956 6000 opt 2 opt 4 and it will get you through to someone for free.
by amovaosobul
Re: flex plan
Thank you very much Dai. I will do.
Re: flex plan
@amovaosobul: You needed to have got a Flex SIM to start with. I presume you have started with an EE PAYG SIM. You cannot switch to Flex with that online or by the text service. You need to phone EE to switch it for you.
