by Jonesy2
Transfer EE Talk and Text plan to EE Flex Plan. Do I keep my existing number
I am looking into transferring from my existing EE Talk and Text pack to a EE Flex plan. Do I need to order a new sim and can I keep my existing number as I am already an EE customer.
Solution
Re: Transfer EE Talk and Text plan to EE Flex Plan. Do I keep my existing number
Hi @Jonesy2
Welcome to the community. Smiley Happy
If you're already on EE pay as you go, you don't need a new SIM and you do keep the same number.
You can change to a Flex plan through the 150 automated system or by speaking to customer services
by Legend
Legend
Hi @Jonesy2
I'm sure you don't, just give CS a call and they should be able to make this change for you. If not then you will need to port out, then back in.
by Star Contributor
Star Contributor
Changing to flex is just a tariff change.
Solution
Hi @Jonesy2
by Jonesy2
Many thanks to everyone.
