by Mitsi Contributor
If i cancel my flex plan for 3 months and restart the same with data earned
Hi can I restart the same flex plan after cancelling for three months and will i keep my free data boost and roll over data.
9 REPLIES 9
Re: If i cancel my flex plan for 3 months and restart the same with data earned
Hi @Mitsi.
If you wish to keep your boosts, you will need to pause the flex plan and resume it again.
If you cancel the plan, you will lose the boosts.
Jon
Hi Jon yes thanks for that
@Jon_K: Is there really an ability to pause a Flex plan?
The Flex plans explained help page says you can pause a Flex Plan but is nonsensical about how to do it:
How do I cancel my plan?
You can pause or stop your plan any time:
 1 log in to My EE and go to Menu > Flex plans
 2 then scroll down and tap the ‘Cancel Plan’ button
A cancellation isn't a pause!  A cancellation is final!
The Flex T&Cs make no mention of pausing.
As I see it in this respect Flex plans are less flexible than PAYG with recurring top-ups, which can be paused & then resumed.
Hi @XRaySpeX
Yes, you should be able to pause the Flex plan through My EE.
I've asked for the steps that you mentioned to be checked and clarified,
Thanks 🙂
Thank you, @Christopher_G, that is what's essential.
Hi X-ray thanks for that
              Mitsi
Hi @XRaySpeX
To pause a flex plan you need to give us a call and speak with customer services.
You cannot pause a plan part way through its cycle and then restart, this needs to be paused at the end of the cycle.
Hope this helps,
Katie 🙂
@Katie_B: It says none of that on the the Flex plans explained help page or in the T&Cs.
Thank you for pointing this out @XRaySpeX, I will feed this back now.
Katie 🙂
